99 V10 questions
Marksman
Marksman
1999 Ram 2500 4x4 SLT
V10
That seems to be what everyone else uses from my research. If you know, what model do you have?
What kind of tune is the one you have? Mpg/hp or? What do you charge for it?
Thanks!
joepizuro
Magnum v10
Thanks!
It's from a 98 Ram 2500 v10 4x4 and no I'd send you it for free. At work we have the software and can write them up. It's an aggressive tune for 91 but the tuner comes with some canned tunes aswell. The forums have Flyin Ryan as a tuner and you can lookup Hemifever!
dapepper9
Iowa/Nebraska Border
5.9L V8
I have marvel mystery oil, i guess i could pour a little into each cylinder. I'll have to disagree with you on the seafoam part, it's some amazing stuff. I have a bunch of carbureted cars that sit for months (sometimes years) at a time without being run, and when they do get started they often run bad-- a little seafoam eats the varnish and clears out the passages and they run good as new again. I've had engines with stuck lifters (my 85 Porsche 944 for example) that wouldn't free up. A couple of ounces in the crankcase freed them right up.
I'll have to get pics of the wrinkle, I didn't take any when I was at the truck (it's not at my house ATM) but i will get some soon. It doesn't look near as good as i'd hoped, but I was doing the swap alone in the middle of nowhere with basic tools so I wasn't able to do it as perfect as I would've liked. I had planned on doing the valve covers the same way, but they were too oily and I ran out of brake cleaner before I got to that part.
Rusty, I like seeing them too. I wish there were more out there.
EDIT: I guess I did take a picture of it. Not very good but you can tell that it's red.
Seafoam is really only good for removing water from fuel. Considering nearly all fuel contains ethanol anymore and that the alcohol attracts water when its left to sit for awhile it's not surprising you notice a difference. MMO is much better at removing varnish and as an additive.
Intake looks good! Nobody does anything with those trucks so it's nice to see
dapepper9
5.9L V8
Sct is the only one i would consider
I have it as well but haven't done anything with it. Have you tuned your truck with it yet?
Marksman
Marksman
V10
I didn't know seafoam did anything to remove water. I've always used Heet for that. A few years ago they made a rule that we couldn't have ethanol free fuel anymore, which sucks. They tore down and are rebuilding the gas station at our Walmart and there's a sign outside that says "ethanol free fuel". I'll be buying my gas from there from now on.
I've read a lot about hemifever, seems like he knows what he's doing. I cant afford a tuner right now, but I should be able relatively soon. I have to focus on getting it driving before i do any of that, but I would still take the tune. I assume its just a file that you can email? I'll PM you my email if it is.
Thanks!
dapepper9
5.9L V8
Thanks!
Ryan is much better. Hemifever is only a sponsor here because 6 years ago he was the only one doing it. Ryan will make the same peak power or more while making 30 or more through the rest of the curve. Much better drivability and reliability
Marksman
Marksman
V10
Good to know.
Thanks!
joepizuro
Magnum v10
I can give you a tune for free that will be decent since the price of tuner alone is almost $300. This is the best performance thing you can do and as cheap as a decent K&N CAI for these trucks which still sucks because our trucks have a factor CAI in front bumper... Also the throttle body spacer doesn't do us any good. So headers, tuner, gearing.. Just food for thought...
I tuned my truck with a tune that I wrote at work, we use SCT Advantage 3.. The tune is set aggresive on purpose. I added some timing, increased fuel plus evened out the torque curve (since it was set for fuel economy esp @ lower rpms even at WOT). Increased the speed limit for OD and removed a lot of torque management @ WOT. I love it, I rip tread early in 1st and soon as she shifts into 2nd. Although I'd give OP one of the milder tunes.
Marksman
Marksman
V10
Is this an emailable file?
Marksman
Marksman
V10
Lol alright, I figured it was. I was just making sure that I wouldn't have to send a tuner to you for you to load it on to or anything like that. I'll PM you my email.
Thanks!
Lloyd33
Army
Ely, Minnesota
8.0L V10
Sorry to resurrect an 8 year old thread, but are these tuners even available anymore (new, used, or otherwise)? I've got myself a shiny new (okay, used) 2001 Dodge Ram 2500 with the 8.0L V10 Magnum engine that hasn't even hit 50,000 miles yet. She's just about flawless! I plan to do some performance mods (K&N CAI, better flowing exhaust, ignition coils from a Viper 8.0L, better plug wires and plugs, etc. and I'd like to back all of that up with a software re-tune if that's still possible in 2024? Anybody have any info? I tried searching the internet for the 'SCT DCX 3200 X3 tuner' mentioned above, but didn't really find anything. I'm thinking that particular model probably hasn't been made for quite some time now? LOL
Dean2
Near Edmonton
I have posted the full service manual for the 1996 V10 pickups. Covers the other motors too.
Have owned one since 1996. My suggestion, leave the factory air system in plave. Unless you supercharge it it already flows way more air than you need and it filters great, which the k and N doesn’t. Also, Viper Coil packs will not improve your performance. Two ENTIRELY different motors with very different compression ratios, fuel mapping etc. I have had Vipers too.
Check your existing plugs, my bet is they are a very nice even tan color. You will not improve on the factory plugs in that motor either.
You can put a tune on the motor and run higher octane fuel, the way it is tuned from factory it will run worse and get worse gas mileage on 91 Octane.
Make sure whoever provides a tune clearly understands how low in the rpm range the truck V10 makes max torque. You can seriously mess this motor up with the wrong tune.
Lloyd33
Army
Ely, Minnesota
8.0L V10
Well, it seems 'back in the day' there were a few folks that made some 'pre-canned' tunes that could be loaded onto these trucks in stock (or nearly stock) form and were pretty widely accepted as generally 'safe' to use. But it appears they were all made for this 'SCT DCX 3200 X3' hardware device that plugs into your OBDII port to flash the EEPROM in the ECU. But the device itself is basically just a file loader. It doesn't contain any built-in 'tunes', nor does it have the ability to edit or modify your existing tune (although I think it *can* create a backup of it), but so it is worthless without the EEPROM 'tune' data files to go with it. I guess I was just hoping maybe somebody still had one of these laying around in their garage and might be willing to sell it or something. I can't imagine there's much market demand for engine tunes for a V10 that hasn't been produced in over 20 years now? *shrugs*
Dean2
Near Edmonton
Getting a custom tune written isn't all that expensive. Just need to make sure you find a real proffessional to do it for you.
Arturo Rojas
