A/C Question 2008 Ram 1500
Admode
Oroville, CA
Hi all, first time poster. I am not a mechanic but I do like to try repairs myself. I have a question that I will try to explain as best as I can:
I just replace the blower motor in my truck. The a/c works well but only when I'm accelerating. I've googled it and it said to try washing the condenser with a pressure washer. If that doesn't work it said that the coolant might be low. Washing didn't work so I got some coolant.
Here's my question: when I have the coolant can connected it shows it being over charged until something engages. I think what's engaging might be the a/c clutch but I'm not sure. When it engages the level goes from being in the red to green and before it bottoms out it disengages and the level goes back to red.
Is this enough information to suggest I might have a bigger problem going on? Thank you so much!
Daw14
South Florida
Find directions for how air conditioning operates in automobiles. Read these directions or visit YouTube so you get an understanding of what should be happening. Finish charging the system. It still needs more gas.
3pedals
Central Valley
So only cools while accelerating or only cools while in motion? Sounds pretty indicative of a failed condenser fan. Idea is while car is moving, air moves thru condenser and cools. But when stationary, there will be no air moving thru condenser without a functioning electric condenser fan.
A
Admode
Oroville, CA
Yes, exactly. When it's in motion it blows freezing cold air. If it's at idle it might as well be the heater. Thank you, I'll look into that.
A
Admode
Oroville, CA
I mean, that's what I'm doing, lol. I don't know how much to charge it since I can't get a consistent reading on the can.
Daw14
South Florida
When the pressure is dropping the clutch is engaged,thus turning the compressor, which makes the pressure on the gauge drop some . Then the compressor cycles, as it should. It engages the clutch again drawing in more refrigerant. The compressor normally cycles off and on like this . Pretty sure it still is low on the charge. Does your radiator have a fan shroud ? While it cycles both inside and outside fans should remain running. As I wrote earlier find information on how it should work , ask friends who work on their own vehicles for assistance or find old guys in your neighborhood and pick their brains. Lots of times folks age out of being able to do the work themselves but do enjoy helping others, and they can get out of the house away from significant others for awhile.
A
Admode
Oroville, CA
That makes sense but the needle stays in the green when the compressor is engaged. It is dropping before the clutch disengages.
If I had someone I could ask I wouldn't be here. Is this not the place to ask questions like this? If so, I apologize.
jws123
nj
The correct reading is while the clutch is engaged If your system was 100% out of refrigerant you might need to evacuate and re charge not just charge. However it does sound like you have a condenser and or clutch fan issue since its cold while your driving. You may be better off just taking it to any shop so they can hook it up to a set of real gaugeswont cost much at all its simple and easy or just find a harbor freight and get oyurself a set of gauges.
A
Admode
Oroville, CA
Ok, thank you.
A
Admode
Oroville, CA
Ok, it just clicked for me. When the needle drops to the green that's the reading. So it's half full. Ugh, thank you so much for your help and allowing me to get through it, lol.
seems fishy
Ontario
Just read your post.In order to recharge your system,you need to remove the moisture from the system as you are replacing your freon.You cannot do that DIY,because you must pull a vacuum on the system.Your can of replacement freon cannot do that.A proffessional shop is really the only way to recharge properly.BTW ,if you overcharge the system you can blow the reeds in the compressor.If it is undercharged it will blow warm air.If overcharged it will blow warm air and put extra strain on your system.I did HVAC ,have my CFC ticket.If you had a proper way to capture the old freon,clean it and pull a vacuum on the system,and recharge the system using a proper charging manifold,with a good recycling and ability to measure correct pounds of freon,tour system uses,it would be safer and your results better.I always recommend staying away from those do it yourself cans of dreon.
sleepy hollow
Great Falls, VA
Maybe I am late to the party, but one thing to mention is that you can get free loaner gauges and a loaner vacuum pump from autozone. I used these to recharge two pickup trucks after having to replace components inside the cabin HVAC boxes. I replaced the blend door actuator on my 07 Ram 1500 Laramie, and then my son's Nissan Frontier's heater core went. I also helped my son-in-law recharge his Chrysler Pacifica mini-van with the 1234yf refrigerant. He hit a critter on his way to work and in a once-in-a-thousand chance, the critter was thrown into his condenser and put a hole in it. Never have seen anything like it. Repair shops wanted very large dollars to fix. I showed him how to do it for about $250, half of which was the refrigerant price gouging.
Now, it is more than possible to charge or recharge your system yourself if you do the required research, make sure you understand how to work the gauges, and also understand the fundamentals of how the AC system works.
Somewhat simplistically, a fully charged AC system with engine off starts out with both the high and low sides at comparable pressures since the compressor is not compressing anything. Then on a warm day, when the engine starts and let's say Max AC is engaged, the system begins to cycle: the low side is compressed to the high side which then decompresses to the low side, to create cold in the evaporator chamber in the cabin HVAC box behind the dash. Pressure sensors placed at various locations along the refrigerant path react to pressure changes to determine whether to keep the compressor on or turn it off. If the pressure goes too low on the low side, or too high on the high side, the compressor is turned off. Turning off the compressor will then cause the two sides to start to equalize in pressure. When the pressure is high enough on the low side and low enough on the high side, the compressor will be turned on again and the cycle repeats. There are other conditions being monitored as well that control the clutch, the electric fan, etc. For example, the cabin temp is monitored to see if the compressor is no longer needed as the desired temp has been reached. Or, the electric fan may be turned on if it is needed to assure airflow across the condenser. Typically, if Max AC is selected the fan will be on by default. Bottom line, if everything is working the way it should, then the basic operation is a cycling between low and high pressure limits of the refrigerant balanced against temperature readings in the cabin.
You also need to know the specs for your car's system which are usually found on a sticker under the hood or in the engine bay somewhere. This sticker will tell you the oil and refrigerant capacities of the system and also the type of oil and the type of refrigerant the system uses. You MUST use the correct oil and refrigerant type for your system. You must never overfill either the refrigerant or the oil. Better to run a bit low on either, but not too low. If you are replacing components of the AC system, then you typically must add some oil since the oil circulates with the refrigerant. So, you may need to add oil if you lose an AC component. For example, in the case of the Chrysler, we were replacing the condenser obviously, and also the receiver/accumulator/dryer. [Anytime you discharge a system completely it makes good sense to replace the receiver/accumulator/dryer which is usually very inexpensive.] You can find help on how much oil to add per component online, but it will usually be 1-3 ounces as I recall depending on what is being replaced. I think we added 2 or 3 ounces to the Pacifica, for example.
The 134A systems and 1234yf systems have different connector interfaces and different refrigerant can characteristics. They use different gauges becuase of this and have different pressure scales as I recall. Others please correct me, but I think I recall that the 1234yf cans screw in counterclockwise vs clockwise for the 134A cans. So, be careful about the details. Think deliberately and talk yourself through each step and have someone with you to verify what you think you did and why.
For example, NEVER open the high side gauges when adding refrigerant, just the low side blue ones. Only open those red high side gauges when vacuuming the system. When adding refrigerant, you only need the red hose to connect so you can read the high side pressure. You don't want to do anything to the high side at this point going forward except read the pressure on that side.
So, with this in mind, you can troubleshoot some obvious problems pretty easily. For example, you watch the compressor when the engine is on and MAX AC is selected. The compressor clutch keeps cycling on and off every 3 seconds or so. Well, this often means the pressure sensors are reading too low on the low side every 3 secs and shutting down the compressor. Then pressure builds on the low side as the pressures on both sides equalize, and it turns on again only to fall quickly and repeat. Possible problem is not enough refrigerant. You might add a bit (say 2 ounces) and see what happens. Often after adding a few ounces, the compressor stays on longer and then you just need to figure out how much more to add to get the system stable and cycling in response to cabin temp, not low refrigerant pressures. That is where the gauges can help. You should be able to find for your vehicle the desired working pressures on the low and high sides for a given ambient temperature and target those pressures as you add refrigerant. Then you'll find the vents blowing cool air and your AC is back in business.
Again, my disclaimer is that this all too brief explanation is general and does not nearly cover all the other aspects of the system that might need troubleshooting. But I have found that most of the time, the system has integrity and troubleshooting can be done around that hypothesis in an attempt to falsify it. Areas not covered that are also common include a leaky system that causes the low refrigerant condition in the first place, a bad clutch coil that will not enage the compressor so you can further troubleshoot the system, a faulty pressure sensor that could be causing your system to malfunction in a way that could fool you into thinking it is low on refrigerant, and a faulty fan or fan control that prevents air circulation across the condenser. These and many others are all possible, but less likely conditions. So, I tend to start with the most common and work down the list. Gauges help you avoid wrong guesses and unproductive troubleshooting if you can get comfortable reading them and watching the system behave through them. And you can simply borrow a set and watch the system operate without affecting it at all. This would be the "read-only" state available with gauges. Keep the valves closed on the gauges and just hook up to the low and high side ports. Doing that alone is a huge step forward for the newbie and can get you comfortable with where the connection ports are, how to hook up the hoses, what to look at on the gauges, and what it all means.
But IMHO the vast majority of issues are associated with getting the system filled and lubricated properly. There are many mistakes that you can make, as with all DIY repair. I have made many and will continue to do so. But I am hoping this brief overview will be of some help as you deal with the problem yourself or enlist a repar shop to help.
I also invite others to correct any errors I may have made in my descriptions. I welcome criticism leading to refinement of my understanding as well.
A
Admode
Oroville, CA
Thank you so much!
