add 360 view to 2016 RAM
vasi
Utah
6.7 Diesel
I plan to tow a 21 foot travel trailer with my RAM 1500 Sport. I want to add a 360 view system. I did a forum search and didn't find any posts on this topic. I am sure those posts exist, so please re-direct me.
1. Is there a Mopar 360 system designed for the 2016 RAM 1500 (I searched the Mopar site and didn't find any)
2. There are several third party 360 systems. Which one has a clear view day and night, with no problems?
vasi
vasi
Utah
6.7 Diesel
My RAM 1500 goes into the shop on Monday to have the 360 view added. Four cameras and a computer to present an overhead view. The display will be on the existing radio display. When the turn signal is activated, the screen shows the appropriate side. The side cameras will be on the bottom of the mirrors. Additional cameras will be added on the trailer as needed. I discussed with Allen, the owner of the company, about having a small display dedicated to the rear facing camera so there will always be a view of what is behind the trailer.
Also being done is some additional turn signal lights, a headlight change to LED, and some bright forward lights mounted below the grill, controlled by a switch. I also want to add some blue running lights below the doors and the same blue light along my travel trailer at the same height.
We talked about flipping the axle on the trailer to raise it 4". I am considering replacing the burgundy graphic on the trailer with flame red to match the truck. If that can be done, it will happen.
NevrFinished
NC
In NC you can’t run blue or red lights on a personal vehicle. Be careful if you’re traveling through certain states, just a heads up.
vasi
vasi
Utah
6.7 Diesel
ah ok, thank you. I want side lights on the trailer so it is more visible at night.
Mpaulsonusn
Nevada
5.7L eTorque
Looking to do this as well. Do yo know what brand and components were used to do this on your vehicle?
Mpaulsonusn
Nevada
5.7L eTorque
Looking to do this on my truck as well. Can you tell me what brands/components were needed to do this or contact info for the shop that did it? Thanks
Steve58
