After swapping O2 sensors, getting 7 error codes
Charlie Evans
Abilene, KS
Hey fellow Rammers.
I need some advice please. I finally broke down and swapped out my O2 sensors in my 08 Ram 1500. Before the swap I was getting no codes, now after changing them I started getting:
P0132 O2 sensor 1/1 circuit high,
P0138 O2 sensor 1/2 circuit high,
P0152 O2 sensor 2/1 circuit high,
P0158 O2 sensor 1/2 circuit high.
I tried to reset the codes and turned it on and off like 50 times codes still there. Today I drove it 100 miles and check engine light went off at a stop. Started it back up and started driving home and it came back on again. But now I have all of the above and
P1128 closed loop fueling not achieved bank 1
P0300 cylinder misfire faul detected random cylinders.
Any ideas where I should start looking?
Did I not torque em down enough? Was told 25ft lbs
Like I said before the swap I had no error codes.
Thanks for any advice guys (and/or gals)
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
Are these OEM sensors? If not they need to be.
DITTO ^^^^^^^^^^^^^^^. OP, did U go way of aftermarket? IF U did, U need to go back and get all (4) OEM sensors and insure you put the correct sensor in each place, as in upper/lower bank. Also check to insure all connections to the sensors are on proper and tight. As far as TQ specs, U just need to Look up and Verify TQ specs.
C
Charlie Evans
Abilene, KS
I'm now not sure if they are OEM or not. A friend got them for his truck and then totalled the truck so I got them. He says he thought the were OEM but isn't sure now where he even got them. I think I'll just buy some new ones and try again.
HemiLonestar
Navy Badge Coast Guard
MD
Nice and easy for 2008, both up and downstream are the same OEM p/n: 56029049AA
rzr6-4
nebraska
'09 2500
No codes before......why did you switch them in the first place?
C
Charlie Evans
Abilene, KS
Trying to get better mileage. Down to almost 12 mpg. Was time for new ones (still the originals as far as I know. I've had it for 12 or 13 yrs and I know I've never changed them.
Jus10case
