Air Ride Pump Fail - "Level Ride Assembly" Replacement
Doug Taylor
Merritt Island FL
2013-2018 RAM 1500 with Air Suspension
Air Suspension Manufacturer
Air suspension compressors normally don't go bad unless there is a leak in the system which will cause the compressor to "burn out". After replacement your shop should spray the systems with a solution of soap and water and look for bubbles which would indicate a leak.
Shameless Plug: When your front struts or rear air springs fail - take a look at Arnott aftermarket air suspension products for your RAM 1500.
  • Designed & Assembled in the USA
  • Built with OE Quality Components including Eibach dampers & ContiTech Air Sleeves
  • Install Manual & Video for DIY work
  • Limited Lifetime Warranty in the USA
More Here: https://www.arnottindustries.com/products/ram-air-suspension
