Front Air suspension replacement
Doug Taylor
Merritt Island FL
2013-2018 RAM 1500 with Air Suspension
Air Suspension Manufacturer
Arnott has a front strut AS-3017 for the 2013-2018 RAM 1500 with air suspension which is brand-new and not remanufactured. If is the first Arnott air strut launched in partnership with Eibach. Both companies worked together to engineer a high-performance damper precisely valved to ride like the OE.
New Arnott Air Suspension Replacement Strut AS-3017 for the 2013-2018 RAM 1500 Features a Custom-Tuned Eibach Shock.
The universal strut assembly fits either the left or right side of RAM 1500 trucks equipped with optional air suspension. The strut also features other tier one components such as a multi-ply cross-cord air spring bladder manufactured by ContiTech, heavy duty crimping rings, oil resistant seals, polyurethane bump stop, check valve and quick connect air fitting. The top is CNC machined by Arnott using aircraft quality aluminum to provide outstanding strength and durability.
This Arnott-designed new RAM 1500 strut assembly is engineered and assembled in the USA and backed by Arnott’s industry-leading warranty. A detailed installation manual and step-by-step installation video is available.
For more information on the company’s extensive line of affordable, high quality, air suspension replacement products now available for more than 150 automotive and motorcycle applications including the RAM 1500 - visit www.arnottindustries.com.
