Am I rich enough now?
cheapbeater
Wisconsin
As you guys know, I have pacesetter LT's, homebrew CAI, and SC 3815 91 tune.
I just put in a 180* t-stat and will do a powerwire sometime... the powerwire doesnt do anything in the winter anyway, right?
Do you guys think i will be rich enough with these mods? I'm waiting till christmas to get an interceptor gauge so i have no way of telling a/f yet..
it smells rich at idle... :********:
thanks
You'll be fine. I had that same setup prior to my cam and the a/f was dead on with LTFT's very close to 0.
cheapbeater
cheapbeater
Wisconsin
was i supposed to drill a little hole in the t-stat? the stocker had one with a little plunger in it. I got the same t-stat as you teach.. had to shave a mm off it.
also, pretty sure my stocker was stuck open..
I drilled a weep hole in the new one since it doesn't have one already in it.
cheapbeater
cheapbeater
Wisconsin
ok. damnit, i suppose i should do it before i dump that expensive a$$$ hoat antifreeze in there
truckin151
2013 sport
What kind of Tstat did you get? if it was a Jet it already has the hole in there
cheapbeater
cheapbeater
Wisconsin
yup. stant because i am cheap...
does it matter that the round plate on the end of the shaft is a little smaller than the stocker?
southalum
