subkron
- Mar 29, 2017
- 21
- 21
- 2015
- Hemi 5.7
I wanted to replace the battery heat shield (some critter got in there and made a mess) so I plugged in memory saver, disconnected battery, added new heat shield, reconnected same battery. I think memory saver collapsed to a low voltage. However, now there is no power - no response to fob (lock/unlock), no cranking, no interior lights, no headlights, etc. Hood light is on with hood raised. When I turn ignition the PRND display on rotary shifter flashes briefly.
As far as diags so far - battery measures 12.3V, checked both fuses (good) at positive terminal, took booster cable from battery terminal to 13mm nut on fuse box, pulled fuse F51 for 10 mins and re-inserted. Nothing at all, really, really dead.
Any ideas?
2015 1500 5.7L
Any ideas?
2015 1500 5.7L
