Belltech 2/4, cant get alignment in spec
hdoggie24
Huntington Beach CA
So annoyed. I contacted IHC. they will not sell the upper adjustable arms separately now and said they will only sell as part of a package with their kits. That's so dumb as I don't need or want to sell their whole kit because i'm happy with what I have now. Hopefully someone will sell theirs sometime in the future. I really think that option is really dumb of them. I may not buy any parts going forward from them now
Mark2011hemi
Canada
I have the belltech 2/4 drop aswell. Caster wont come back. Just make sure there even and wont cause issues. You shifted the rear forward so it wont go back. In terms of caster on my 4x4 i extented the upper control arm mount bolt holes out rouglty 1/4" and then took the welder and filled backend so bolt cant move. Worked great!
mert34
Alaska
2019 Classic
mine are coming off but cost of shipping makes it not worth it from alaska typically
Dragonsteel
MIssouri
After reading thru this thread and taking the view point of someone doing their first 2/4 drop to their truck. I am thinking one should go with the IHC kit and use everything except the lower front A-arms and purchase the Belltech front springs. That way you get their 4" rear drop springs and all the good geometry fixing parts for the rearend, then use the IHC upper A-arms for getting a good alignment, while using the Belltech front springs for the 2" drop. Then If you wanted to go lower later you already have the parts on hand. What do you guys think?
abouttobeglue
abouttobeglue
Dragonsteel, good idea, pretty sure you can get the front springs for 100-150, check walmart. How much cost wise did it work out to be?
I'm at
300 for bt 2/4
150 for shocks
100helper bags
500 for the illicit brackets
350 for their install
300 to trim front tie rod
125 alignment
1050 parts and 650 labor.
Also other parts I've tried
160 in belltech nitro shocks
150in kyb gas a just
130in kyb great shocks
Dragonsteel
MIssouri
I'm at
300 for bt 2/4
150 for shocks
100helper bags
125 alignment
IHC kit lists for 1260
Belltech front 2" drop springs are 179
Belltech front shocks are 112 for a pair
Total of just over 1500.00
Bluestarrider
North Carolina
Be careful with the IHC upper control arms. They possibly wont work with your wheel tire combo. I purchased a set and can't use them. Control arm tire interference!
Dragonsteel
MIssouri
Please provide more info. What wheel and tire combo did you have the interference with and where did it interfere? I am gathering all info I can before pulling the trigger on the combo I listed above.
Mopar2keddie
El Cajon California
I would imagine the IHC works with stock tire sizes on stock 22in wheels. You can't expect them to try every possible combination out there.
Majority of trucks don't have 22" rims,most of them have either 17's or 20's,shouldn't be hard to check either of those sizes for interferance .
Midnight Storm
One Badass Ram
Victoria, B.C Canada
Rim size doesn’t mean anything. It’s the overall tire size that can change things. I have 24’s with the exact same 33” overall diameter as stock 20’s.
Extra wide rims and not knowing offsets can get you in trouble.
JustinRam1500
