Best wheel spacers?
Dante221
Ardsley NY
Hemi 5.9
Hello All: :sad72:
Well it appears from my reading that I will (may?) need a 1/4" spacer to fit
35/12.5/20 tires after a 2" (or 2.5"?) leveling .
Is there a "best" product for the 1500 i.e. a set made ONLY for
the Ram ? Also do you recommend front AND rear spacers or only as needed
in front?
Thanks
Dante
mattman_13
Some put them in front only. I ran them on both because I'd notice the slight difference and go crazy.
Make sure you buy a solid machined piece not some cast bs. When installing our lugs come from factory with a little lock washer on one of them on each hub. You'll need to remove that so your spacer can seat flush and get no vibes.
I ran rcx with no issues.
express20122
motorsporttech.com hub wheel centric 3/8" made especially for ram 180.00 for 4 highly recommended
