Biggest tire you can put on a 20" stock with no lift
ralphdagza
2015 RAM 1500 Sports/Crew Blackout
thinking about upgrading my tires. mine came with 275/60R20
How big can I go with out needing a lift???
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
Depends on if you want tall or wide.
275/65/20 will fit. That is 34x10.8x20.
If you go wider, then you need to go shorter.
You cant go taller.
jasonw
South Dakota
5.7L Hemi V8
Confirm 275/65R20 fits without a lift or level kit. Use this size myself. No rubbing.
RamOR
EcoDiesel
I run 35x12.5 with slight running at full-lock.
jasonw
South Dakota
5.7L Hemi V8
Wow. You sure? What is your metric siZe?
According to some Jeep websites...
35x12.5/20 = 318/60/20
34x11/20 = 275/65R20
Its half an inch higher than a 275/65/20, and only about 2.7% different in revolutions per mile. However, it is far wider, over 15% wider.
wsutard1
Woodinville, WA
HEMI 5.7 eTorque
It's the wider part that I thought would cause the issues. It isn't turning ona flat surface. It's turning while at a pitch or hitting a bump.
jasonw
South Dakota
5.7L Hemi V8
Can you post a pic?
Don't have any straight side shots, and its dark out now. Can get some later if the below don't satisfy you (taken last month).
Lowrider357
