Biggest tires on 2500 HD
Bwhackd34
PA
What are the biggest tires you guys are running on a no lift no level Tradesman 2500 4X4 diesel with SnoKing package....
Has 8” rim option....
want to go with 315/70-18 toyo OC MT
I have seen some saying they will work and others saying not....kind of looking for a definite answer...
what are you running?!?!?
Southern_yank
Northwest Arkansas
I changed it to a 305/70/18 about 6 months ago. Slight rub on sway bar at full lock. Nothing on radius arms that I have seen.
2020 tradesman CTD with off road package. No lift or level. Mounted on stock chrome clad wheels
Sent from my KB2007 using Tapatalk
mtnrider
Georgia
315/70-18 is going to rub for sure. Probably pretty bad. I'm running a 305/70-18 with a 2.3" level and no issues but I bet even the 305 will rub stock. A 12.5/35-18 is a little shorter then a 305 and I have heard that people can run them stock but it has to be real close. If it's just a highway truck it may not be an issue but offroad may be another story. Also a 8" rim is pretty narrow for a 12" wide tire. That's below the minimum most ire manufacturers recommend.
Brian2081
Weatland Michigan
I'm running Falken MT's 35x12.5 18 on stock rims, full hard lock just the slightest of rub on radius arms. Haven't seen any rub marks on the sway bar yet.
GeometryFletch
Arkansas
6.4L HEMI
35x12.50R18 BF Goodrich AT KO's, no issues at all for me. 2020 Tradesman 2500 4x4 Hemi
Dave Dillard
Belton Tx
i got these dinky 245/70 R 17 on my 4x4 tradesman. What the biggest i can go without rubbing or a lift?
