Brake light wiring issue.
25RAM00
Riverbank, CA
Magnum 5.9
All 3 lights not working for brakes. Fuse is good. Power is present on one fuse post. But when I go inside to the brake switch, I have power to the pink and blue wire but no power to the white and tan. Checked all wires with switch on and off also brake on and off. Any ideas? I'm new so sorry if this has been covered. I didn't see this issue searching previous threads.
sbarron
Wasilla, Alaska
One set (your WT/T?) would be power going past the switch when he switch is closed? bad switch or a bad ground?
Good luck. Keep us posted.
