itswiggs
- Jul 30, 2024
- 37
- 35
- Location
- texas
- 2022
- pentastar etorque
I’ve been through these forums countless times now. Trying to research, but really need help trying to figure out where wiring needs to run.
Purchased 5th gen seats and console and have a 2022 1500 classic 4th gen. The new seats are powered, memory, heated and ventilated out of a 2021 limited. I sourced a female connector to match the 5th gen seats and have started working the pin outs over to the new connector from my plugs. I400 and I420 Are the ones on my factory harness. The limited connectors are the xy420 and xy410.
All that being said. My factory harness only has the wiring for the inverter to passenger seat, seat belt and occupant detection. I also have power and ground on both passenger and drivers side. I don’t have anything else.
What I need help on is, where do I run the wires to and from. I know the memory has something to do with the door modules and memory pedals, what wires go where. Does anything pin out to the bcm or do I need to go to the fuse box?
Or can anyone recommend a website for wiring diagrams and I can try to figure it out.
I’ve been using the Mopar connector repair website and see what the pin outs are on what plugs but, what plugs are what? And where are the wires coming and going?
Thank you in advance for reading this and taking the time of you do help. I appreciate it greatly!
