Cleaning flat black trim
Turbo67
Somerset, PA
TOP COAT, You can do your whole truck with it, works great
Kinetic
Solution Finish is good, so is Carpro DLUX and Gyeon Q Trim. You can also try Wipe New found at Walmart, I've had very good results and longevity with it.
bfill_rebel
bfill_rebel
Thanks for everyone’s input. I’ll look into these products.
That spray from chemical guys looks easy to maintain appearance.
Schultzestrength
South Carolina
I use 303 Protectant. I don't have much experience with anything else, but this stuff works well. I use it on all exterior non-metalic and non-glass surfaces. I also use it on my entire interior. It seems to last a fairly good amount of time too.
Purplert
Car pro dlux
JB1
Houston, Texas
I use aerospace 303 on everything
Same here
bfill_rebel
bfill_rebel
Same here
So after doing some research on various sites (mainly Jeep Wrangler forums) I noticed a common recommendation was to use a Mr Clean magic eraser to get wax residue off the plastic trim and then 303.
I already use 303 on my interior and I had magic erasers as well. I tried it and it worked great. No more faded areas of wax staining.
Ramnewbie
I've been using Lucas spray mist for years, works well on any exterior surface, no discoloration on flat black trim. Now I will say it's not a hearty wax but it only takes minutes to wax the whole vehicle. I go over mine after every wash as a finishing touch.
JB1
Houston, Texas
Sometimes you don’t need 10 different products that specialize for 10 different things, just the 303.
gixxer
SK Canada
4.7L
Wolfgang exterior trim sealant, it’s great for metal as well.
303 is another great product.
Maxima SC1 (its a motorcycle product) it’s a silicone product that I spray on after I put a protectant on. It leaves an incredibly slick layer on that is not permanent. Bugs come off so easy and it gives a beautiful shine. I spray it on the front of my truck after a detail.
rambloch21
Coral Springs, FL 33071
bfill_rebel is right on! Used magic erasure then 303. Spectacular results! You will have to reapply the 303 after it gets washed off by rain or whatever, but its easy and works great! The magic erasure works like a miracle on any kind of residue on black porous or flat trim.
Treburkulosis
Glorified Car Washer
Haslet, TX
My method of cleaning is I use this to clean it.
Then as said before there are multiple options that work. Solution finish, Shine Supply Clutch, Carpro Dlux or like what I have used on all of my vehicles Undrdog Pro. Dlux or Undrdog will give you the longest life. My wifes jeep is at 14 months and still looking great.
Timkll
