Clicking Noise
egrande04
5.2L 318
there is a clicking noise on my truck every time the tire rotated. I replaced the U-joints in the front end and in the drive shaft and the ball joints. There isn’t a rock or screw in the tires so I’m at a loss. Could it be the wheel bearing?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Clicking like a rock in the tire? Have you checked wheel bearings yet? What about a look at the brakes?
MADDOG
Living in a Firepit
Don't rule out a broken cord in the tire, either. If you want to check for that, jack up the front end and rotate the wheel.
dropkicknick
el paso
easiest way to check wheel bearing is to jack it up and grab top and bottom part of tire and try to push/pull it. there shouldnt be any play.
rotate tire a few times and do it again
E
egrande04
5.2L 318
I’ll check all of these this weekend. Thanks for the advice. I’ll post an update later on.
marininn
feathr
5.9 24v
Cheap steel wheels will flex under the heavy truck and click. Perfectly normal.
cdub5
