Code po299 and po243
Anthony silvestri
Ontario
Eco diesel
Hey there new to this forum thanks i keep getting this codes P0299 and P0234 I already changed my map sensor cleaned my mass air flow sensor changed my air filter and fuel filter took out and cleaned my inner cooler also cleaned my egr to the truck has 180km I did the delete when it had 50km been great until now there is no smoke or power loss just goes into limp mode when code is tripped I clear it and I’m on my way again used to do it only when I towed with it then I figured out that if I kept it above 2000RPM it didn’t trip it but when I was not towing everything was fine now it started doing it when I’m not towing now anyone else have this problem and possible solution thanks greatly appreciated
Raadz
