Cold starting the Cummins
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
I have been having problem starting my 6.7 cummins with push start button. Not always but sometime when I try and start the truck I step on the brake, push the button and the truck immediately cranks the motor, no wait for the grid heater. last night it happened again. The outside temperature was -26'C (-15'F), I opened the door got in stepped on the brake, pushed the button and expected a pause for the grid heater to warm up but immediate crank of the engine, of course it didn't start, coughed once and stalled. Pushed the button again and immediate crank again, engine coughed and stalled again. I than removed my foot from the brake pedal and pushed the start button twice and the grid heater went through its cycle, I cycled it twice (for good measure) than stepped on the brake pushed the button and again immediate crank but this time the engine started and stayed running as I had manually warmed up the grid heater. Is the truck not supposed to determine the outside temperature and run the grid heater on it's own depending on it's needs. Sometime it runs the grid heater on its own and sometimes not. Just trying to figure out what is normal.
MADDOG
Living in a Firepit
It should hesitate to start given that temperature until the grid heater warms up. Sounds as if your truck needs some diagnostics performed.
1quick1
Colorado
haha I can already tell your first 3 trips to dealer. All will be "tested and all works as expected"
CDN Ram
CDN Ram
Ottawa Ontario
2014 Laramie
6.7L CTD
That what I think as well, but I drove it several times this weekend and all worked as normal. I wonder if a low battery would cause this malfunction? As it had been weeks since the truck was last driven, after I finally got it started and drove it all seems to work as normal now.
Probably right on that one.
Fred 2500 Ram Tradesman
Maine
6.7 Cummings Diesel
After I bought my truck I realized it didn't have the block heater cord installed. I went on Amazon and got a cord for $26 and installed it. Big difference coming up to temperature on my 17 minute drive to work. I also put a grill cover on it. A must in my situation. I don't have a push button start, so it's up to me to see the glow plug light go out then I turn the key.
