Considering rebuilding a pre def Ram, ie 1996 to 2002.
Robeffy
Northern Ontario
Cummins 6.7 TD
Hi,
I am looking for a project, and looking for advice on model years to consider rebuilding. I am narrowing in on a 2nd Gen Cummins 2500, automatic, 4 wd, opening rear doors, 6 1/2 or 8 ft box.
This DEF nonsense is to be avoided.
Computers are over rated, the minimum computer stuff is the best in my opinion.
I guess, go with OBD 2... eliminates anything before 1996.
The opening rear doors on the cab mean 1998 or up, that eliminates anything less than 1998.
IF 1998 and later, that means a VP44 pump I think, as long as its 1998.5 model year. How about the P pump- 1998 to 1998.5 model years.
Let the discussion start!
Thanks in advance
JayLeonard
6.7 L Cummins
I would want a P pump truck. They are very robust and easy to make power if that's your thing.
Robeffy
Robeffy
Northern Ontario
Cummins 6.7 TD
Just did some reading... seems like you need to understand how to setup the P Pump, which is mechanical, vs the VP pump which has a lot of electronics involved.. I don't need tons of HP, I just want reliable and pulling power. I am trying to stay away from electronics, computers, etc.. Seems like P pump, even capped at 500 hp , is more than enough. I know its overkill, I have a 4500 lbs travel trailer and want to tow around, without worrying about hills. I may end up with a much bigger trailer down the road.
Thanks for the feedback
