Couple lift questions
DKnight521
I've been looking at the RC 6" lift (PN: 32230) for my truck, but I just bought some Cooper Adventurer A/Ts back in November. They are 275/60r20. Going to look a bit small but would I be able to keep these as well as the stock 20" rims until they wear out or would i need new wheels/tires? Also, anybody have this lift? Is there a better one out there that won't break the bank?
LaramieGen4
Eastern NC
You can definitely keep them. If it were me, I'd keep the lift in the box until I was ready to spring for new tires, and wheels too if you want them. I'm running 285/65R20's on just a level so you should have no issues with your tires and wheels with any kind of lift whatsoever.
As for the lift, it's probably okay. Asking what's the best lift is kind of like asking what's the best tire - you'll get differing opinions. I was going to do their 4" lift, which is really not different from the 6 other than the height. I just don't want a lot of extra height but I want to fit the tires and wheels I want. Since the 4" and up requires a lot more expense and cutting, I'm looking at maybe doing the 3" bolt on if I can tell there will be clearance for some 35's with negative offset wheels.
D
DKnight521
Good to know! It's hard to find a lift for 2wd. Would I have any issues with the lift and 35's or 37's with the stock 3.21 gears? I wouldn't imagine it'd cause any issues but just trying to cover all the bases
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
from what I've read, because I'm on 3.21 gears also, you should be fine with 3.21 and the 8 speed trans. I'm not sure on the 6 speed.
D
DKnight521
Just what I was thinking. I've got the 8 speed. Most of the 2wd kits I'm looking at lift the front 2-3" more than the back. Will that level it or will I also need a leveling kit? I don't want it to Carolina squat or anything like that
shadowhawk
Southeast WI
I just did the Bilstein install on the front, and I'm actually sitting a little nose high. I'm going to add daystar spacers to the rear. If you go Bils, setting them at 2.1 should maintain just a little rake.
D
DKnight521
Will a lift alone not level? Sorry, new to the lifting world for rams. I know a lift with an F150 levels as well
JB1
Houston, Texas
His truck is 2WD :deal:
JB1
Houston, Texas
Does that mean the lift will level as well? Or will I need a leveling kit in addition to a susp. lift?
I’m just saying your 2WD truck doesn’t use the Bilstein adjustable height struts he was referring you too.
shadowhawk
Southeast WI
I didn't realize you were 2wd, so my comments apply to 4wd
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Mine below, Maxtrac 4.5"/3", and I have 8 speed, 35's and 3.21's....and its 2WD
Graygoose
Oklahoma
Convert, for now.
small
No sir, let a shop local to me do it. They said it went together very easily, rides like a dream!
and thank you for the kind words!:favorites13:
blackbeautyhemi
Lewistown, PA
Yea it will level it. Rough country 6” lifts are 6” in the front and 4” in the rear for that reason.
ameer73
