Cut belltech rear springs. Sitting at 2/5
Ramcharger60
2016 crew cab sport
Looks great. The front looks lower than a 2" drop. Did it measure out at 2"? Here is mine with the IHC 4/620180124_102639.jpeg
Sent from my SM-N960U1 using Tapatalk
predat-r
4.7 v8
I'm loving the 2/4 drop on mine can't go any lower winters out this way suck plus my wheels are too wide.833a3501ffb3c68e64406e88279209ec.jpg
Sent from my SM-N920P using Tapatalk
Txhemirt
Txhemirt
Lubbock, Tx
Looks good man. What tonneau and spoiler do you have ?
Dallas tx
HEMI 5.7
No idea man, that’s what they cut out. Truck is sitting dang near level and not hitting frame so far. I plan on getting illicit brackets soon anyway
Well that’s the important part that it sits where you want it, & it looks really good man
Txhemirt
Txhemirt
Lubbock, Tx
I'd like to know as well!
2 turns exactly on each spring
Here’s the measurements he provided
Before
FL 33.25. RL 34.38
FR 33.38. RR 34.63
After
FL 33.5. RL 33.38
FR 33.5. RR 33.7
You'll want Ryans/Illicits "cut" versions if you're down past 4".The easiest way I've found to install the cut versions,is to drop the diff right out.It makes getting at things that need trimming a lot easier. Doesn't hurt to run a couple weld beads on them along with the bolts,if you have access to a little mig welder.Plan on close to a day to install the brackets,they do take a bit of work to get installed.
512RAM
Austin, TX.
Before
FL 33.25. RL 34.38
FR 33.38. RR 34.63
After
FL 33.5. RL 33.38
FR 33.5. RR 33.7
The fronts grew in length? I'm jk. Thanks for the numbers!
dearchristopher
Galveston, TX
man i miss my drop. looks good.
i dont miss that cruise ship swaying from the lower control arm geometry lol. if you don't have them already, get some LCA brackets
