fasthemiram12
- Mar 11, 2013
- 804
- 206
- 2012
- Eagle 5.7 vvt
This thread is to clear up some confusion and also to inform everyone on the gear/lsd options for 2011+ Rear Axles.
I just had a DTT and 4.10's installed in my 2012 Ram.
It was quite costly.... Roughly 1500.00
This is only for those that want to go all out race or serious 4x4'n
Here is what is needed:
1. 9.25 Ring and Pinion. Any ratio size you want, 4.10, 4.56 etc.
2. 9.25 Detroit Tru Trac. Install as normal.
3. 2011+ Ram (Drivers Side) ZF Axle Shaft (Longer Side) Part # 68140297-AA
4. Master Install Kit
The reason a long side shaft is need is because the OEM ZF LSD is offset while the 9.25 DTT or 9.25 LSD is not.
For those with 2011+ that just want to have 4.10 or 4.56 gears and already have a Factory LSD, all that is needed is to machine the OEM carrier for the older 9.25 bolt pattern and recess the holes.
Those that do not have an OEM LSD would obviously need to purchase one.
Gear swap for Front IFS for 2012 and Up is not available.
The Ring gear is welded to the carrier and is not serviceable at this time.
Only option is to Swap to an older 8.0 IFS Assembly from a 06-11 Ram and then order gears accordingly.
Note: It is better to get whole assembly not just the chunk.
IFS, CV Axles, Diff bracket, Front Driveshaft etc.
