tmcgraw
Diesel Treatment or Not? I have a 2018 3500, 4 wheel drive dually, diesel. Carry a camper with close to 5000 lbs. Some suggest diesel treatment others say No.! Thoughts, thanks
Worked?? yeah at reducing the lubricity of diesel fuel and doesn't do the DPF any favors either.2 cycle oil was actually one of the better and cheaper additives that worked.
I'll let you know when it happens. 48k miles half that has been on MMO. My father runs alot more than me with 138k on his. Neither one of us ever had any emission problems. Ever. Our trucks empty are just shy of 10k #s and we don't baby the trucks. I'll continue running it since I'm directly seeing positive results.If you’re driving a tier 4 emissions truck I would highly recommend you do not use marvelous mystery oil in the fuel. It will create scr and DPF issues. In my experience dealing with fleet trucks simply run an approved diesel additive during the winter months if you live in a cold climate.
I’m not trying to convince you of anything. You can run whatever you like in your fuel. It’s your truck so ultimately I could not care any less.I'll let you know when it happens. 48k miles half that has been on MMO. My father runs alot more than me with 138k on his. Neither one of us ever had any emission problems. Ever. Our trucks empty are just shy of 10k #s and we don't baby the trucks.
You're not going to convince me it will cause issues or self destruct.
But here we go again, the same rabbit hole everytime someone starts a thread about additives. It's as bad as Syn Oils.
I said what I had to say. Everyone have fun.
In my current 2022 2500 CTD I use 1-2 oz Opti Lube Boost ( https://opti-lube.com/opti-lube-boo...thout-accessories-treats-up-to-2-560-gallons/) in ever tank, IMHO it works based on mpg with and without addtive, during the colder temps will treat the fuel with anti gel when temps are expected to go below 36 degrees because in Portland metro area by law all retail diesel is mixed with a minimum of 5% Bio, in my old 2006 5.9 I could use almost anything I wanted with out worry from 2 cycle oil to Howes, Power Service, Lucas as it had no DPF or EGR to worry about clogging up...Diesel Treatment or Not? I have a 2018 3500, 4 wheel drive dually, diesel. Carry a camper with close to 5000 lbs. Some suggest diesel treatment others say No.! Thoughts, thanks
Well, the thread got interesting.Diesel Treatment or Not? I have a 2018 3500, 4 wheel drive dually, diesel. Carry a camper with close to 5000 lbs. Some suggest diesel treatment others say No.! Thoughts, thanks
I'm a firm believer that you do not try to out do the design of the system. Living in SE Idaho where we have pretty cold winter conditions, the only treatment I use is Power Services anti-gelling treatment which is a staple out here.I’m not trying to convince you of anything. You can run whatever you like in your fuel. It’s your truck so ultimately I could not care any less.
I said what I had to say. Eye roll and laughing.
