Dodge Ram Cold Air Intakes Diesel and Gas
SlickCar Trever
Check out our selection of Cold Air Intakes for the Ram. We carry all of the name brands like AEM, Injen, AFE and more.
For a complete listing of 1994-2013 Ram Cold Air Intakes click here.
As always if you have questions let me know by PM, Email or just call me 954-728-9588.
I listed some of our top selling Ram Intakes below.
Thanks for your support.
Trever
Dodge Ram V8-5.7l Hemi 2009-2012 - Afe Stage-2 Cold Air Intake
• Pre-positioned opening for stock attachments to avoid dangling wires
• Incudes reusable lifetime filter
• 99.2 percent filtration efficiency
• Delivers a throaty performance sound
• Replaces the entire stock air box
• Recommended for Increased HP and Torque
• Easy to install with factory fit connections
• Sold as a Kit. Hardware and Instructions Included
• Manufactures Description: AIS P5R; Dodge RAM 09-12 V8-5.7L HEMI
• Intake Type: STAGE-2
• Make: Dodge
• Model: Ram
• Years: 2009 2010 2011 2012
• Engine: V8-5.7L HEMI GAS
Dodge Ram 2003-2008 1500, 2500, 3500 Hemi 5.7l V8 - Injen Power-Flow Air Intake - Wrinkle Black
• Specifically designed for horsepower and torque gains in trucks and SUVs
• Improves acceleration and fuel economy.
• Uses the patented MR Technology tuning process to ensure the air/fuel ratio is within optimum limits
• PF Series Air Intakes are CNC mandrel bent for unrestricted air flow
• Includes reusable, high-performance cotton-gauze air filter with a built-in velocity stack
• Includes stainless steel clamps, silicone hoses and detailed instructions for a do it yourself installation
• Constructed from T-6061 billet aluminum for light weight and excellent corrosion resistance
• Large increase in filter area over the stock airbox filter results in a huge increase in airflow and a greater capacity to capture and hold dirt.
• Dyno-proven & Tested for maximum and reliable horsepower gains
• Available in Polished or Black Finish
• Made in the USA
• Intake tube and air filter are covered by a Lifetime Warranty
• Horsepower Increase: +13
• Torque Increase: +12
• Intake Tube Color: Wrinkle Black
• Make: Dodge
• Model: Ram
• Years: 2003 2004 2005 2006 2007 2008
• Sub Model: 1500, 2500, 3500 Hemi
• Engine: 5.7L V8
Dodge Ram 2003-2004 Diesel 5.9l Cummins AEM Brute Force Air Intake
• CARB Exempt: Yes
• Easy Installation. Direct Bolt On
• High Quality Finish
• Mounting Brackets, Filter and Tube Included
• Make: Dodge
• Model: Ram
• Years: 2003 2004
• Sub Model: Diesel 2500 3500
• Engine: 5.9 L Cummins
Dodge Ram 1994-2001 1500 Pickup 5.2l V8 F/I K&N Performance Intake
Guaranteed to Provide more HP and Increased Acceleration. Engineered for your Specific Dodge Ram. Easy to Install, Usually in 90 minutes or less! Lasts up to 100,000 Miles Before Service is Required (depending on driving conditions) Million Mile Limited Warranty Replaces OEM Filter and Air Box Air Filter is Washable and Reusable Works with Original Equipment Manufacturer Computer Systems Designed to use the Ram Factory Holes & Mounting Points Whenever Possible Street Legal in Most States.
• Make: Dodge
• Model: Ram
• Years: 1994 1995 1996 1997 1998 1999 2000 2001
• Sub Model: 1500
• Engine: 5.2L V8 Gas
Dodge Ram Diesel L6-5.9 / 6.7l 2003-2009 - Afe Stage-2 Cold Air Intake
• Manufactures Description: AIS PDS; Dodge Dsl Trucks 03-09 L6-5.9/6.7L
• Make: Dodge
• Model: Ram
• Years: 2003 2004 2005 2006 2007 2008 2009
• Submodel: Diesel
• Engine: L6-5.9/6.7L DIESEL
