Downsizing Wheels on 2020 Ram 1500 Big Horn
Haystacks
Corona, CA
Ecodiesel, 3.0 liter, v6
I did some searching and couldn't find this exact issue addressed. I have a 2020 Ram 1500 Big Horn 4x4 Ecodiesel, and I'm looking to give it a moderate off road set up. Nothing crazy, just a 3.5" lift with 35" tires. It comes stock with 20" rims, and when I told the guy at the off road shop I was looking to downsize to 17", he said that's a no go. They had a 2020 Rebel in the shop and were trying to put 18" wheels on it. They had to grind down a particular spot on the outside of the brake calipers to get the 18" wheels to fit. When I called a couple Ram dealerships and spoke to the service department, they confirmed that there is not an aftermarket 18" wheel that will fit my truck. Has anyone here found an 18" wheel that can successfully replace the stock 20"?
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Here is a list of the 18" wheels that will fit your 2020
1. Vision Rocker 18x9 -12 offset
2. Fuel Rebel 18x9 -12 offset
3. Fuel Zephyr 18x9 +1 offset
4. Fuel Clash 18x9
5. Fuel Trophy 18x10 -12 offset
6. Method Envy 18x9 -12 offset
7. Method MR305 18x9 -12
Look for wheels that are 18x9 with -12 offsets ... You wont have a problem with them .. Those dealerships are full of $Hlt!!!
CanRebel
Toronto
My 2021 Rebel come with 18 from Factory.
I put 20's on my truck.
Both dealer and off road place you went to are stupid. As it was mentioned above. there are many that would fit.
brian42
San Diego, CA
OEM 18" wheels will fit since they are the same brakes on on all trim levels (don't know about the TRX though).
The don't clear the calipers by much but they do fit (I have 18" OEM wheels).
You have to be careful with aftermarket wheels as they might have clearance issues based on their specs (as you have read above).
18" is the smallest you can go. My 18s clear the caliper by 1/4" - 3/8" inch.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
I originally put 18’s on @b8ascrub truck with a 2” leveling kit and 35 x 12.5’s so I can absolutely confirm 18’s can be done. Now his truck has a 6” lift riding on full length fox 2.5 coilovers with reservoirs dialed in with the same wheel and tire combo
brian42
San Diego, CA
I revise my statement. After looking at the clearance this weekend I've got 1/8" at best between the caliper and wheel.
The tape weights my shop uses to balance my wheels go off-center inside the rim otherwise they would probably rub on the caliper.
aeromax4
Brookhaven, Pa
My 2020 Laramie came with 18's and I'd like to upgrade to OEM 20's. Would this change affect the computer or the calipers? TIA
Rlaf75
East Hartford CT
As long as you use the factory size 20" tires you should have no problems. The overall diameter of the stock size 18" tires are the same as the stock size 20" tires. The 20" tires have a shorter sidewall than the 18" tires but the overall diameter will be the same. My ram came with 20" and I swap to 18" for the winter and the speedometer is exactly the same for both. I checked with a GPS to verify
Ssamt75
Ga
Do you happen to know if 285/65/18 will fit factory wheel without contacting upper control arm. Seems like they will.
brian42
San Diego, CA
I wouldn't think so. The Rebel runs that size.
The wildcard is the wheel. The OEM 18x8 is the smallest wheel that fits so there's not much wiggle room outside of OEM specs for an 18" wheel.
My Big Horn had 275/65-18 tires and had some room to "breathe" on the stock 18" wheel. With the Rebel only have a +1 tire on the same 18" wheel (same specs, different visual design) there shouldn't be any rub unless you start modifying the suspension also.
TestPilot57
Vermont
Key point.
Aftermarkets are not just "18 x 8", 18 x 9", 18 x 10" etc. The dimensions spec'd are for the ID of the TIRES. In addition to offsets, there is the profile of the metal that makes the wheel.
Ftank
