Dual Alternators
GeorgiaTrains
Covington,GA
OK - I am specking out the options on a New RAM3500 DRW and see the option for Dual Altenators - what does that give me in electrical options?
Administrator
Unless you need to extra power of the dual alternators for running a snow plow or a large capacity winch all the time, the standard or high capacity single alternator is plenty of power to run everything you'll need for your truck.
Most of the time people need a second battery instead of a high capacity charging system, as in the case for a winch, stereo system, etc.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
Same voltage, just double the amperage output. Hydraulic pumps and such on snow plows rigs can draw north of 100 amps.
GeorgiaTrains
GeorgiaTrains
Covington,GA
Well maybe here is what I really want to know. Is there a 110 plug in available inside the truck bed to power an accessory?
Scottly
Safety Harbor, FL
HO 6.7 Cummins
I had a single alternator and had one of those. It comes with the gooseneck prep package, if you have the 110v option inside of the truck.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
If there is a 110 volt inverter on board, they are only really rated to charge laptops and other smaller current draw things. Looks like you have to get laramie longhorn trim and above to get it standard.
turkeybird56
Central Texas
Don't waste yer time with the lil 110V in truck. Older were good for 100 Watts, newer were 400 watts. U just gonna be able to charge a phone and such. Nothing, nothing heavy duty. U wanna do HD stuff, U would need to get like a 2000 W full sine inverter and wire in.
brian42
San Diego, CA
Second alternator powers extra stuff when the truck is running and an extra battery powers extra stuff when the the truck is off (and provides extra current to start a diesel).
My F-250 had dual alternators which was uncommon in personal applications (fairly common in commercial applications like ambulances, etc.). While it was great to have that extra juice it was twice as expensive to maintain/repair. If I was ordering a truck I would go with a high output single unless I was adding power-hungry accessories.
GeorgiaTrains
GeorgiaTrains
Covington,GA
That answered my question - I was wanting to maybe charge batteries on my 5th wheel RV - doesn't sound like it would work very well.
joesstripclub
Lees Summit, MO
2021 2500 PW
From what I've read in a couple discussions lately, the 7pin wiring is pretty small and can't push enough current to really charge RV batteries. Better off getting a solar panel IMO.
brian42
San Diego, CA
My dad only had a single alternator in both his HD trucks and towed his RV trailer regularly (his last one was a 40+ foot 16.5K lb 5er) and never mentioned wishing he had a second alternator in his 40+ years of RVing.
Tulecreeper
Sthrn AZ
Oh, it will charge them, it just trickle charges them at around 2 - 3 amps. It's enough to keep a fully charged battery topped off, but if you've been camping and ran your RV battery down 50% don't expect it to be charged up again by the time you get home unless you're driving cross-country.
Jerred17
