Hemi drifter
I've taken on swapping the cab and box from one truck to another. Here’s the backstory. 3 years ago I bought a beautiful 2016 Ram Eco diesel LIMITED with 115,000km. Very (very) shortly after buying it the motor blew. Private sale and not the sellers fault, but effing sucked. Took the engine out and brought it to a guy to rebuild it... and he screwed me over and disappeared with my engine, Number disconnected everything. So long story short I've had this $30K paper weight in my driveway for over two years with no engine and missing a bunch of wiring, the turbo, etc etc.. At long last I found a donor truck. Hallelujah! Same frame config (4x4 crew cab short box) but lower trim level and body is beat up. I got it for 8k so I jumped on it. My plan was/is take the body and box off the limited and throw them onto the donor frame with running engine. I completed 95% of the swap tonight (just missing the box). I connected the battery and everything came to life as expected. Turned it on and it fired right up!! BUT...it shuts off after two seconds. It did that a few times and now wont even turn over. I know the battery in my fob is weak so I'll change that in the morning , and I also intend to purchase Alpha OBD to see what I can see and reconfigure there... but I'm stumped as to what the reason might be that it's doing this. Almost feels like a safety feature, like anti theft maybe, but not sure. I do have one harness block coming out of the cab and it has no mate coming from the frame, so that might be an issue, but I also suspect that it's for the air suspension which the donor frame does not have (I could be wrong, but would make sense). I scanned it and got 3 codes of note:
U0001 CAN C Bus
P26A6 Engine coolant Bypass Valve Sensor circuit low
P0513-00 Invalid SKIM Key
The fob I used to start the truck is the one that goes with that cab. The ECM is the one that matches with the donor engine as it has been tuned (EGR / DPF Delete and Stage 2 tune) .
I'm bummed because I'm soooo close to having this truck back on the road after 2+ very long years! Has anyone done this before? Anyone here work at a dealership and have any idea of what it could be?
I don't have a picture unfortunately of the lone connector, but it's grey fairly big and square with about 14 wires going into it and it comes out of the cab at the back of the driver front fender.
Thanks in advance to anyone who can help shed some light on the subject
U0001 CAN C Bus
