Egr delete but not removed
SouthEast
3L ecodiesel v6
A mutual friend of mine introduced me to his friend that had a ecodiesel jeep a few years ago. He said all his mechanic friend did was cap the two holes with metal plates. Disconnected some other things and that was it. I looked online and the kits are $50ish and a dozen small pieces.
I understand this is vague, but it's only for the purpose of discussion & education.
So can it really be that simple?
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Just like with a gasoline powered engine
you don't want any oil to enter your Injectors & then into your Combustion Chamber, ONLY AIR, gas or diesel is suppose to do that.
watch this video
you need a Catch Can, another name for it is a Fuel/ Oil / separator
which is something like what a automobile Painter uses
they place a Water /Air Separator in the Air Line that feeds the Paint Gun.
What it does is removing the Water from the Air, so they don't get water in the Paint
nlambert182
Huntsville, AL
I can't imagine that it's that simple from a tuning perspective. From a hardware perspective, that's really all there is to it. BUT.... your ECM is programmed to monitor certain parameters in the EGR/emissions system and my thoughts are that if those parameters skew due to missing equipment that it's going to throw a code and put the truck into limp mode until it is tuned out.
At least that's how it is on the 6.7 Cummins.
