Electronic Gremlins are becoming tiresome
Travelin Ram
Today’s event was “camera system unavailable”. Occurred on startup in the middle of the afternoon. Shifted in and out of reverse, no bueno. Tried the surround cam icon repeatedly, not available. Went away on the next start later the same day.
For context, the truck has intermittent glitches with the XM radio, TPMS, Stability control, and probably a few more I’ve forgotten. Oh yeah, the automatic door locks. And the weirdness with downhill compression braking. And the rear locker light that flashes.
Nothing crippling, and always intermittent, but not confidence inspiring when you’re 25 miles from pavement, like I was today.
When I get back home later in the year I’ll take it into the dealer and have them run some diagnostics, I’m hoping maybe they’ll find some fault in the network that’s affecting multiple systems. If not, it may be sayonara. My tolerance for malfunction is not very high.
tpk0999
The current unconnect system doesn't seem as smooth as previous version. In my opinion atleast.
Sent from my SM-N986U using Tapatalk
T
Travelin Ram
Today’s weirdness: crossing a mountain pass the temperature display went down to 49. Probably about right. And it stayed there as I descended. No change in displayed outside temperature for about an hour or more, as I descended several thousand feet. Over several stops and restarts. Finally, later in the evening it jumped up to the mid 60’s (about right) after being parked 20 minutes or so. Seems normal after that.
I think there’s a poltergeist on the canbus or something.
