Engine will not Start
gbryant
Kansas
HEMI 5.7
Please help!
My engine will not crank... no click either... just nothing. Although lights and bells work.
Door locks work with or without key. Key engine start seems to go through proper sequence too.... just no crank ... or click.
My battery is good... just had it tested.
I just replaced the TIPM.
What else should I check?
edit: The last time it started.... it started hard , like low battery. The battery gauge reads low (analog) the battery is good...
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Are dome lights pretty dim? I'm gonna say that the battery is bad even though it tested good, I had a similar issue and this was the case. I would try to pull the positive terminal off the battery and let it sit for about 10 minutes then reattach and try it again .
SilverStreak88
Houston, Texas
5.7 Eco Gasser
I think the starters are pretty much good to go... i wouldn't think that a truck this new should have an issue like that.
G
gbryant
Kansas
HEMI 5.7
I took the battery out, took it to battery store, tested good , brought back, re-installed.... nothing.
How did you determine the battery was bad?
SilverStreak88
Houston, Texas
5.7 Eco Gasser
all my lights were very dim and batt gauge was low. I replaced even though it tested good and it'd been a champ ever since. Did you check fuses? If a fuse for ignition is blown for some odd reason it will produce similar symptoms.
jwheeler
Washington
Little red security light blinking in the cluster?
G
gbryant
Kansas
HEMI 5.7
OK... Ive ordered an XS Battery (been wanting one anyway) when that arrives it will take the bad battery question out of the equation.
G
gbryant
Kansas
HEMI 5.7
I've read about the possibility of a WCM (wireless control module) being bad. Any thoughts?
I wonder if the pushbuttons on the keys would work if this were bad??? They do work...
sylver91
This is how car companies are making hard for the little guy to do his own repairs at home or small shop anymore. Almost any of the diagnosis required today needs a scan tool.
As for the starting issue, it works from the wireless ignition module to the TIPM through the CAN BUS. What you can do is check that there is power coming from the TIPM to the starter. There is also a ground control for the starter relay through the PCM.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
This is the argument I have with a lot of guy's on here, they don't seem to understand that the electronics are great, but are not bullet proof.
HANSOME
i HAVE A 1998, WITH A FACTORY SECURITY SYSTEM. ON MY TRUCK, IF YOU REMOVE THE BATTERY, YOU MUST RECYCLE THE SYSTEM. ONCE AGAIN, ON MY TRUCK, THE TOGGLE SWITCH IS DOWN LOW ON THE STEERING COLUMN. IF YOU DONT DO THIS, YOU WILL GET NOTHING, NO CRANK AT ALL.
jbmobbs
murfreesboro, tennessee
if it turns over
1 put a spare spark plug in one of the wires or coils and have someone turn it over. if it sparks then its not the ignition system. if it does not then its plugs, wires, coil(s), cap or rotor button (if yours has one)
2 check fuel psi on fuel rail by pulling cap and pushing the valve down if fuel shoots out then not your problem if it does then bad fuel pump.
3 its probably not suffocating. but check iac solenoid.
needs air, fuel, spark to run
sylver91
Lol try explaining that to customers who try their own diagnosis. All they do for me is add extra work to fix what they did. I'm all for people fixing their own cars, just remember they ain't building them like they used too.
G
gbryant
Kansas
HEMI 5.7
I took it to dealership, it was the starter.
But, low tire pressure light is still on.... the saga continues...
LB3711
Trumbull, CT
3.6L V6
make sure everything is plugged in and everything is seated properly on the TIPM. I had mine replaced by the dealer recently. Also I think it needs to be programmed.
