EXTENDED WARRANTIES FOR NON-FORD MODELS @ GRANGER MOTORS!!!
GrangerMotors
Supporting Vendor
Granger, Iowa
Granger Motors Has Some Great News!!!!! :)
For a while now, our Warranty Department has been known for selling Extended warranties for new/used Ford and Mopar vehicles.
Now we are selling ESPs to cover ALL MAKES AND MODELS!!!!
Whether you own a BMW, Chevrolet, etc., you can buy an Extended Warranty through Granger Motors!
Requirements:
  • 2015 and up
  • Below 80k miles
  • Inspection required if out of factory warranty
WEBSITE IS LIVE!!!
Vist https://grangerwarranty.com/
We are known for selling warranties at an amazing price while still providing the best customer service. We could not do this without all the support you guys have given us!
Please let me know if you have any questions.
06 Dodge
6.7L CTD
Requirements:
  • 2015 and up
  • Below 80k miles
WEBSITE IS LIVE!!!
Whom is this service contract through, as in the name of the company?
GrangerMotors
GrangerMotors
Supporting Vendor
Granger, Iowa
Over the weekend, things have changed regarding the years/miles that an Extended Warranties can be purchased.
To purchase an ESP for your vehicle, it must be 2020 or newer and under 60k miles.
Fords still in Factory Warranty or out of - https://grangerfordextendedwarranty.com/
Mopar still in Factory Warranty or out of - https://www.buymoparwarranty.com/
Other vehicles - https://grangerwarranty.com/
We are still $25 over dealer cost for Ford/Mopar.
I am sorry for any inconvenience.
Birdie Boy
TN
Huricane HO
Requirements:
  • 2015 and up
  • Below 80k miles
WEBSITE IS LIVE!!!
I looked at your site, and there have been some big changes just from a few weeks ago. It does not appear your warranty covers internal engine components? Who is the insurance company that you are using to back your plan? Would it not be better if your plan describes what it won't cover? The MOPAR plan you had previously looks better.
sorry for Butting in ..
In November, i was hunting a warranty, i even considered the non Mopar After Market stuff
I bought a Mopar Policy for my 2016 Ram
It was called a Mopar Used Vehicle Warranty
My Ram was under 65,000 miles & I took it to a nearby Dealership & had them do an Inspection, they checked everything !! & only found my Wiper Blades were bad.
I regret that i did not know about Granger,
I went to the other dealer with discounts, with a Z
GrangerMotors
GrangerMotors
Supporting Vendor
Granger, Iowa
If you currently have a Mopar vehicle, you will want to go to https://www.buymoparwarranty.com/ as that will be an ESP directly from Mopar! This site will be the $25 over dealer cost as well.
etbrown4
Since Granger doesn't cover internal engine parts, it would have no value to me.
Seems lousy. Doesn't cover AC either. Does someone think us Ram forum guys are dumb?
Engine parts covered:
(Note, no cam, no pistons, no crank!)
Engine​
  • Flywheel Ring Gear
  • Fuel Tank and Lines
  • Gas Fuel Injectors and Fuel Lines
  • Harmonic Balancer and Bolt
  • Manifold (Exhaust and Intake)
  • Manifold and Bolts
  • Oil Pan
  • Oil Pump
  • PCM Module
  • Radiator
  • Radiator Fan (Clutch or Motor)
  • Seals and Gaskets
  • Thermostat
  • Thermostat Housing
  • Timing Chain Cover
  • Timing Chain (Gears or Belt)
  • Turbocharger/Supercharger Unit (Factory Installed)
  • Valve Covers
  • Water Pump
06 Dodge
6.7L CTD
Engine​
  • Oil Pan
  • Oil Pump
  • PCM Module
  • Radiator
  • Seals and Gaskets
  • Thermostat
  • Valve Covers
  • Water Pump
I just read this at Granger's about factory powertrain engine coverage and it includes internal engine parts that one would naturally assume includes the cam, crank & pistons and it does, read below:
Engine​
  • Cylinder Block and all Internal Parts
  • Cylinder Head Assemblies
  • Timing Case, Chain, Gears, Belt and Sprockets
  • Harmonic Balancer
  • Oil Pump
  • Water Pump and Housing
  • Intake and Exhaust Manifolds
  • Flywheel with Starter Ring Gear
  • Core Plugs
  • Valve Covers
  • Oil Pan
  • Oil Filter Adapter Housing
  • Turbocharger Housing and all Internal Parts
  • Turbocharger Wastegate Actuator
  • Supercharger
  • Fuel Injection Pump (Diesel engines only)
  • Fuel Injectors (excluding clogged injectors)
  • Serpentine Belt Tensioner
  • Seals and Gaskets for Listed Components
etbrown4
Granger has more than one warranty. Beware of no engine coverage
