Factory EGT probe manifold tap
Brandon Fortner
Denver
Hemi 5.7l
Excuse my ignorance if this is the wrong thread. 2012 2500 SLT 6.7l. I am wanting to relocate a factory Chrysler EGT sensor/probe to the exhaust manifold in the collector. I cannot find a definite answer to if this probe will be able to withstand 1400 f° long term. I don't want to get a stand alone pyro since my ezlynk has the EGT parameter already. The stock sensor does sync with it so I'd really like to use it if possible. I tried splicing a thermocouple probe since I know they can handle great heat but was unsuccessful because the ECU only reads from NTC thermistor type probe (factory probe style). From my understanding thermistor type probes aren't made for extreme heat which makes sense because all of these sensors/probes are post turbo. I have not been able to find a max temp for these probes. Part # 5149085AC
Thank you
