front differential
Carsongj2530
I’m going to be rebuilting my front diff soon and I was wondering what’s the best kit out there, if there’s any better gearing to go In the front, and also what would be a good hearing for a 6in lift with 35’s for better gas mpg
smithwessn
Are you asking what gear ratio you should go with for the front diff? You can't change the ratio in just the front diff. The front and rear diff have to be the same ratio or you will destroy the truck when using 4 wheel drive.
chrisp2493
Always Modding
Warren, OH
392 Hemi
Moe’s performance sells a good front end rebuild kit. The fronts are very pricey, it’s about $300 for the large install kit. And you have to keep the same ratio or change the back to identical gears. Have you ever done a gear swap before? It’s not easy at all and takes some special tools. I would recommend 4.56 ratio if you are inclined to change them out
I Bleed Ram Trucks
chrisp2493
Always Modding
Warren, OH
392 Hemi
Also what year truck? You are posting in the 3rd gen section (02-08) and your profile pic looks like a 4th gen. They have some special issues with the front diff depending on the year
I Bleed Ram Trucks
C
Carsongj2530
I Bleed Ram Trucks
My truck is a 03
C
Carsongj2530
I Bleed Ram Trucks
So a 4.56 ratio would be good with the lift?
chrisp2493
Always Modding
Warren, OH
392 Hemi
It’s not necessarily about the lift as much as the bigger, heavier tires you are rolling around on. But yes that’s a great ratio for the 3rd gens. I’m using them on 33” tires, the rpms will be higher cruising the highway but the extra mechanical advantage is well worth it in my mind
I Bleed Ram Trucks
C
Carsongj2530
W
I Bleed Ram Trucks
what mpg do you get?
C
Carsongj2530
Also how do I tell what size ring gear I have like if it’s 8in or 9in etc
chrisp2493
Always Modding
Warren, OH
392 Hemi
I’ve got a big built motor, I barely pull 10mpg. It will be different on a stock setup. As long as you have a 1500, the rear is a Chrysler 9.25” diff and the front is a Chrysler 8.25”
I Bleed Ram Trucks
C
Carsongj2530
Okay I have a stock 03 1500 i know I have 3.55 gears so 9.25” in rear and 8.25” in front?
Goodie1990
