msnyder1112
I've had some convos going on another forum but that forum seems to have dried up... not much activity.
I have a 2019 RAM 1500. It has 29k miles on it. I am lifted with a RC 6 inch lift (save the hate please).
I'm getting a clunk in the floorboard when coming to a stop. It also clunks when I accelerate a little heavier. It does not clunk on rough terrain at all.
Now the kicker....
If I slow down, and it clunks, but I dont fully stop, it won't clunk again. It's almost like it has to "unclunk".
If I accelerate a little heavier to the point it clunks, then I can get it to clunk upon slowing down.
I had it in to the dealership to check over everything. They said the LCA balljoint had play and the axle was making some rotation noise. I'm out of warranty and didn't want to pay almost 3k for those... so I went with mevotech ttx UCA, LCA, and replaced both sides axles with trakmotive. Also noticed the tie rod boot was torn, so I replaced that. I put in energy swaybar bushings and moog end links too.
I took in the TSB on the body mounts to have the dealership check them and they said they are fine, with the understanding that I would pay out of pocket, since warranty is up.
I'm dropping the truck off to a reputable indy shop Tuesday to investigate, but I like to give as much info/suggestions as possible. I did tell them about the TSB on the body mounts, but I'm not sure there is any way to actually test that.
Anyone have any other ideas what this clunk could be? Brake caliper? Driveshaft?
Now the kicker....
