Front end noise
Ottawaman
Canada
2023 1500 classic hemi. only 4000 kms on it and I hear (and sometimes feel) something around the driver front end when curving left on a downward slope. I cant explain the sound ...its not grinding or clunking....more like a steel rod running along another steel rod like you're sharpening a knife.
Any ideas? Im going to have a hard time describing this to the dealership.
rzr6-4
nebraska
'09 2500
Given the year I would suspect you’re under warranty. If so, let it be their problem.
If you’re not under warranty, from your description sounds like maybe a wheel bearing but don’t take that as gospel. Jack up the front, make sure that everything that is supposed to move does and everything that’s not supposed to move doesn’t. Usually not too hard to find.
