Getting all 8 coilpack codes !eletrical issue!
Royh
Ellijay
So i picked up a 02 ram 4.7 2wd sport 97k miles had a spun bearing .put new crank kit, new timing kit, gaskets. ect... Got motor back in an everything hooked up .crank it up an running rough . (no power to obd port) so i check codes by turning key 3 times . its throwing p0351-threw p0358 (all 8 coil pack codes) i have no power to radio . no interior lights work unless switch is turned to on position. Hord dosent work unless key is on. Head lights/brake lights wont work unless switch is turned on.
Update: so i let it run for awhile (45min) press the gas it spit an sputtered an died an will not crank back just spins over. Now it will not display codes by working key 3 times. Only thing in interior that works without key is adjustable pedals and seats. The door locks dosent nor the mileage display when door is open.
Can someone please shed spme kinda light on this
I've looked over wires and ground straps from what i can see an reach nothing is pinched or broke. I checked all fuses/relay.
I did replace main power wire that goes from battery to starter .
Saleen5150
