having an issue with my 4.7 ram
Liam Gracey
london ontario canada
I'm wondering if anyone has had this issue before and is able to help, so i have a 2013 ram 1500 with the 4.7L V8 and I'm noticing when cruising the rpms will fluctuate (around 100-300 Rpms) i just recently noticed this issue.. I'm hoping that it's not a transmission issue but i'm not sure.
my truck is at 91000 kms as of right now, it is also just rear wheel drive if that effects anything.
Nate4x4
The Vehicle Reader
ON, Canada
5.7L Hemi 4x4
It sounds like your torque converter is locking/unlocking to maintain the speed.
Nate4x4
The Vehicle Reader
ON, Canada
5.7L Hemi 4x4
Does that mean the torque converter is going out? Or is that just regular operation ?
See if you can duplicate the surge without the cruise on.
Very lightly touch the brake pedal just enough to disengage tcc, without applying brakes, if the surge goes away, it is the tcc.
Liam Gracey
Liam Gracey
By cruising I meant just normal driving not having the cruise control on, but the other day I noticed it was doing it and I put the truck in neutral and it was still fluctuating. I find it won’t actually fluctuate if the cruise is on. I was thinking it could be a sensor or something like that.
Nate4x4
The Vehicle Reader
ON, Canada
5.7L Hemi 4x4
Okay, sorry for the misunderstanding. It's more than likely the throttle body. It will need to be cleaned.
https://www.ramforum.com/threads/rpms-fluctuate-on-my-dodge.16919/
southalum
