Cwils80
So I definitely know our trucks have a little bit of pedal lag. I know all the different options that can "get rid of it" and everything. But I've thought about buying a PC and here's my thoughts and I want to know who agrees with me, and if you disagree, with me why do you think I'm wrong?
I'm my profession (network engineer) your connection is only as fast as the slowest link. I believe that carries over to a lot of different things and I believe this is one of them.
I could be wrong in this and correct me of I am but the PCM reads the throttle position sensor and tells the throttle body to open up to whatever percentage.
Now if this is true then you will always be tied to how fast can the pcm read the sensor. How fast can it tell the TB to open up and then how fast can the truck responds to the TB opening up.
I'm my opinion plugging a device into the pedal itself can't make every other device react faster unless every other device is programmed or changed to read faster.
Am I correct in my thought? Am I wrong? If I'm wrong can you explain to me why? It would help me convince myself to get a Pedal Commander lol
