help with rear differential
matt1881
I have a 2004 5.7L hemi my rear differential has gone out. I'm not sure where to look to find the gear ratio or even what it could most likely be any help would very appreciated
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
If you don't have a sticker on the rear diff or a stamped aluminum tag on the rear diff then I would suggest you contact Chrysler for your build sheet. The build sheet will tell you what gear ration was put in the truck as the assembly plant.
This is a link for the build sheet.
Contact Dodge
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
A good guess can be made off of what size wheels it originally come with? 17" normally 3:55, 20" usually 3:92. Look at the door jamb sticker. Or pull the rear end cover and count the teeth.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
In the Glove Box there should be a white sticker and on the Info listed one line should say Corporate Axle 3.55 or whatever else (3.92), The 03's have the sticker and no Tag on the Diff (mine Anyways).
Greg's 17" wheel theory is probably bang on for a 3.55 Guess.
moparman
Woonsocket, RI
2016 Ram 2500
You could also pull the diff cover with the axle on jack stands and spin the assembly until you see the ratio stamped in the ring gear. 17 inch tires could also have 3.21 too
Sent from my Galaxy S3 using Tapatalk 2
M
matt1881
thank all I will look in the glove box to see if there is a sticker in there...mine came with 20" on it orig. is it true that dodge had a recall of rear diff from 02-09
Ramunit
Negative on the recall
gville35
