HELP!!
WTM75
Upstate NY
3.6 Pentastar
I just changed out my steering wheel to a leather steering wheel with audio controls and now my service Airbag light is on. I took it back apart to ensure the connectors are connected and they are. What is the next step?? Thanks
SYKRAMMAN
Banned
Jersey shore
06 Mega
I’m not 100 sure it works on newer models but disconnecting the negative battery cable for a couple minutes usually does the trick.
huntergreen
Marine Corps Navy Badge
I got nothing other than the battery disconect.
WTM75
WTM75
Upstate NY
3.6 Pentastar
I got nothing other than the battery disconedis.
Tried that. Had it disconnected when i did the switch install. Then disconnected it to try and reset the airbag system.
CLOUDL1GHT
Lone Star State
Cummins HO
Did you make sure you held the clock spring in it's original spot?
When I changed mine I didn't do that and had my traction control light on and cruise control wouldn't work. Maybe on newer models it's the airbag light that comes on.
Just out of curiosity, is it the original airbag?
WTM75
WTM75
Upstate NY
3.6 Pentastar
My clock spring was out, no airbag light. Took it back apart, fix clock spring, put it back together. Now know traction control, but I have the air bag light. I've taken it apart again to check the connections, I've disconnected the battery, again to try and reset it, even put the original wheel back on, nothing fixed it.
I took it to a dealer, they hooked it up and said I need a new airbag control module.
huntergreen
That's a crazy coincidence.
joshhhh
