how do i tell my truck i changed tire size?
Midnight Storm
One Badass Ram
Victoria, B.C Canada
Op,
Do you have the before and after tire sizes? That will tell me exactly how far it would be out, if at all.
another fun way to calibrate tire size for you with a ‘17 is an edge pulsar. It will give you some power or economy upgrades as well. A little more pricy than some of the options listed above but it’s good stuff.
db208
i got alpha obd, ($50 alpha obd program), ($60 mx+ obd connector on amazon) connected through my android phone via bluetooth. changed tire size to 35's and it fixed my speedo which was off by 3mph after installing bigger tires. also able to tweak many other settings with this gadget.
Blue Truck
Skagit County WA
No Spark Plugs
Use something like https://tiresize.com/calculator/ to figure out if you need to do anything at all in the first place based on entering both tire/wheel sizes.
Love that site! I'll add some description on how to use it for your situation. On the left side, click on the "Tire Comparison" tab next to the "Tire Calculator" tab. This allows you to compare existing tire specs to potential ones, complete with diameter, revs per mile, percentages, etc.
tdp1
What about the odometer? Do bigger tires affect the miles racked up on it making the truck resale worse?
boblonben
Just tell it like u would tell your friend... "Dude, I put bigger wheels on you". In all seriousness, I don't think you can on the newer Rams. If there's a way, I don't know it. But as far as I know, just try to compensate a little on the speedo
Sent from my SM-N975U1 using Tapatalk
Is the tire diameter the same ?? If it is you do not need to do anything. Otherwise find someone with a programmer that fits into the OBDII port and you can tell the truck computer what new tire size you have. Easy....
tidefan1967
Summerville, South Carolina
No on all counts. Taller tires turn fewer revolutions per mile traveled so if you didn't correct the speedometer you would actually have less miles not more. That being said when I did it I bought a used Hypertech Speedometer Recalibrator off of eBay for less than $100 to correct mine three years ago.
slacadjuster
5.7L
*****..."Dude, I put bigger wheels on you".
fingus42
