How do you clean under the hood?
EWC88
Southern NJ
Curious how you guys keep the engine looking clean and the underside of hood?
LS5DodgeRam
South Florida
4.7L v8
Some soap, water, a rag, and some degreaser(when it gets bad) almost the same as detailing the outside
Pull Ya
Cedar Creek, Tx
Depends on how dirty it is. There are lots of speciality cleaners out there, however I use Simple Green and it does a great job and in most cases it's cheaper than most.
Jay
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Compressor Air blows off the dust then just wipe it all with damp microfibre towels and I then wipe on and shine it with Gunk degreaser with built in shine stuff, Oh and the Truck I use the pressure washer after winter and dry it off with the air.
E
EWC88
Southern NJ
When using simple green and hose, should I put a plastic bag over alternator/fuse box/ battery? Anything else should I cover?
audio1der
Airdrie, Alberta
I cover the coil packs if I'm spraying the engine off, that's about it.
Typically I wipe it down with a quick detailer and use simple green where needed.
WhiteExpress
Midland, TX
I don't soak anything under the hood, but I've never covered anything (other than an open intake) and never had an issue.
I have a long reach soft bristle brush (saw it at Lowes) that I use to 'scrub' stuff after a quick spray with simple green. quick rinse and dry with a Mircofiber.
It's not show quality under the hood, but it's pretty darned nice.
E
EWC88
Southern NJ
So water getting into alternator will be ok? I don't want to screw myself lol
audio1der
Airdrie, Alberta
Once in a while AND if you dry with forced air, you should be fine. I drove a car around without the hood for a week in the snowy spring and that killed the alternator LOL
E
EWC88
Southern NJ
Lol ok, air compressor be ok to blow air out of it or should I do my leaf blower? Hoping I can do a good cleaning next time it's real nice out and I have a day off lol.
Sharp Charge
Brunswick Oh.
I don't cover anything but I don't use any high pressure either. If you break out the power washer you may want to cover the sensitive electrical stuff.
LovedMy 2500
