How to block autostart of the radio and CD player
shagya
Hungary
5,7 L HEMI
I can't find a solution in the menu of blocking "autostart" of the radio and CD if one is in the player. It sucks every time after starting engine.
Anybody can help?
Thanks !
Rlaf75
East Hartford CT
Am i getting this right? You do not want the radio to come on when you start the truck? If that's what you're talking about then turn the radio off before turning the engine off when you get out.
British Bulldog
Jacksonville NC
Hemi 5.7 etorque
I am certain on gen 4 trucks you cannot turn the radio ‘off’
Only mute or turn volume right down. It will always come on at volume otherwise. Even mute will ‘unmute’ on start up. Always was a pain in my 2017 truck.
I could be wrong? Do 21/22 classics have a turn off switch?
John Jensen
San Diego County
Ecodiesel
^^^^^ Correct, no way to turn the radio off. Have to turn the volume down if you don't want to hear it.
18harvest
huntsville
if you don't want the cd to play as soon as you turn the vehicle on take the cd out.it does this on later application versions of the panasonic radios no matter what setting is on the radio when you cut it off .never had a problem on ra3/ra4 radios or a 22.6 application version on a panasonic.
shagya
shagya
Hungary
5,7 L HEMI
Thanks for all comments!
Goodie1990
