I need to replace my HEMI, what am I in for?
TheOcho8
Reno,NV
I have a 2003 Dodge Ram 1500 HEMI. My truck has been having a **** idle. And today I put my compression gauge on the engine and found no compression in the number 4 cylinder. So I need a new engine.
My question…..what am I in for? I have replaced engines in the past. Just not on this truck.
Also where is a good place to find an engine?
HemiLonestar
Navy Badge Coast Guard
MD
Start simple. Pull the valve cover and look first. Get a borescope or similar camera and take a peek down that cylinder. Anything catastrophic will be painfully obvious.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If you bought the truck new, or you know the trucks history
If that engine has never been rebuilt, then i would take it to machine shop & have them inspect the block & heads.
If they can't find anything wrong with cylinder #4, a rebuild may be the better way to go
aviatorblackout
NC
You might just have a broken valve spring. The metal in the early 5.7 hemis valves springs were an issue and would give you a crappy idle. If it runs better with higher RPM I would bet thats the problem. You can repair this without removing the head too, just make up a holder out of wire or something to hold up the valve when you remove the old spring
Martins hemi
Alabama
I had to have all my valve springs on my 03 replaced due to breakage
HemiLonestar
MD
165k and counting on my original 2003 valvesprings lol
Dodge 1500 4X4
Rochester, NY
Broken valve springs, can hold the valve open and give you a bad compression reading, A leak down test will tell you the condition of your cylinder rings and intake and exhaust valves, do you have a shop compressor, and you can purchase or rent a leak down kit.
HemiLonestar
MD
Mine went out at 172k so…your close lol
Good news is I’ve put nearly 200k since then
I'm not worried. I had almost 200k on a set of 2006 springs. Maybe I'll leave them in longer to see if I pass you lol. If it grenades the engine then I can just plop the 6.1 in.
ameer73
