I wanna go lower.
ARMYRETIRED
Greenville, NC
6.7 Cummings Turbo
i currently have a 2/4 setup and with the new lower profile tires it seems that another inch front and back would be better visually. Questions are:
I just need to cut a coil at each corner right?
How do you measure a coil? (a complete circle?)
Are there any further precations to take after cutting the springs?
Thanks
Chris
mikehutch
New Boston, Mi
I would suggest you plan on doing this is smaller steps, a few times and going slow not full coils. You can't put back what you cut off. :)
I don't have my numbers handy from my 08 Front but I did 1/4 circle (~4-5 inches in length) and it was probably close to 1" drop.
Hopefully someone with 4th Gen might have some experience with these coils can chime in.
quietpeen
2021 TRX
Hellcat
big boi cut his coils, hopefully he chimes in with some tips
WhiteExpress
Midland, TX
When I cut the coils on my '98 Ram, I did it 1/4 coil at a time.
(I was already running a 3" drop coil. Wanted like 3.5")
ARMYRETIRED
ARMYRETIRED
Greenville, NC
6.7 Cummings Turbo
robby5323
East Texas
2014 Single Cab
Here's what I would do. The variable spring rate is different with drop springs vs. the stock springs. So, if you want to cut a little off the lowering springs to achieve another 1" drop, I would start with 1/4 of the coil. Imagine the coil as a complete circle, cut off 1/4 of that circle. By doing it this way, you don't risk going "all in" at once and can fine tune it as you go. If the 1/4 off doesn't give you what you are looking for, you can always take off a little more. But, once they are cut, there is no putting the coil back to the previous "uncut state." There is no definite amount to tell you to chop off. It will be trial and error.... Hope that helps a little... (I've cut all 4 of mine)
ARMYRETIRED
ARMYRETIRED
Greenville, NC
6.7 Cummings Turbo
Well I made the cuts today. Only the rears, did 1/2 coil at a time and ended up removing 1 full coil from each side. The overall result was 1 inch front and rear but left enough for settling.
Mad Cow
Anchorage, AK
Cummins 6.7
I like it looks good. I plan on doing the same thing with the front Ram head as you did.
chipmaker
AZ
Looks great, how does it ride??
09SMOKINHEMI
TEXAS
sweet looking ride.... now all you need are some red/black JJ lights and that will look killer
BigH0ss
Banned
So u cut a full coil to give u an inch? I wanna do this on mine too. Well more that an inch but did u notice any difference in ride?
KAKA
