I want to lift my 2WD 2018 Dodge Ram
Kaido
Riyadh
Hi guys,
I'm new here, I want to lift my 2WD 2018 Dodge Ram.
I can't find anything for 2wd, everything for 4x4 so far.
I want to lift it 2.5" front and 1.5" rear
Any advice will be great :)
View media item 30716
View media item 30715
Thanks.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Hi guys,
Thanks.
I'd recommend their control arms. They give you back suspension travel on the lift.
Kaido
Kaido
Riyadh
ram1500rsm
Trabuco Canyon, CA
Factory ones were good for stock. You should go with aftermarket ucas that have a built in offset for 2.5” lift. You have different options to choose from. Main price difference is bushings, BJ/uniball and frame construction. Anything that doesn’t feature a standard BJ like JBA, Icon Delta Joint, or any of the arms with offset and uniballs will allow you to use shocks with extra travel, if you went with the Fox shocks they have more travel than stock.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Kaido
Kaido
Riyadh
Looks good!!..........did you do the springs yourself?
Thank you :)
I did the rear spacer, And 2 of my friends did the front one at the same time. We finished everything in less than 3 hours.
Its came with good instruction paper. Thanks to MaxTracStore.
az88
saudi arabia
Hi guys,
I lifted my 2WD RAM :D
Rear 1.5" Lift Spacer
Front 2.5" Lift Coil Springs with MaxTrac Shocks
Before
After
View media item 30797
What do you think? ;)
hey, how's the 2.5inch maxtrac 2wd front lift doing with you?
because I'm considering buying it,
is the ride quality good?
and does it effect the upper control arms?
SSGTD
