Info on installing a brush guard
Billythe kidd
New Hampshire
5.9 Cummins
I have a heavy duty brush guard that I want to install on my 99 Ram 2500. looks like I need to remove the bumper bolts as part of the two brackets attach to where the bumper bolts go. I am certain that as rusted as my bolts are they will break when I try and remove them. Does anyone know the size of these bolts as I may need to get some that are slightly longer to accommodate the extra width of the bracket?
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
If you lube them good with a good penetrating oil, they shouldn’t break but unless someone chimes in with the exact known length on that, you may just have to run down to your local hardware store or tractor supply if ya got one and match your bolts there.
