Is there a 3rd brake light for 2022 that will strobe?
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
I've looked everywhere... why wouldn't a newer year like my new 2022 have an LED strobe 3rd brake light?
You can buy them all day long for older models before 2019
I'm new to this year of my Bighorn... still learning it. Is there a setting that makes it strobe???
geeeezzz for all i know it's already built in???
joelmic
joelmic
stl mo
Nope. I have a Tazer DT that allows me to strobe my third brake light in my 19 Laramie Longhorn and so much more. Here is the link to see if they have one for your Bighorn.
https://www.zautomotive.com/ Just put in your info.
This is the same thing as the OBD2 reader and AlphaOBD?
Or different?
joelmic
joelmic
stl mo
TRK_GANG74
Navy Badge
Va, Hampton Roads Area
Haven’t had a problem in Va where I live. Many many times I’ve had VSP and local police right behind me or beside and behind me on the local roads and highways without ever being bothered for over 2 years now. I have mine set to flash 15 times then it goes solid red.
Hawkman
South Carolina
PSA: Flashing CHML's are illegal. Some modulating CHML's are legal.
Not in all States. I used the Z Automotive module to activate the CHML on my ‘24 Rebel, no issues. I also have flashing brake lights on my Harley. Have for years in Md, and now in SC.
Not illegal in either state.
Green_Manalishi
No in all States. I used the Z Automotive module to activate the CHML on my ‘24 Rebel, no issues. I also have flashing brake lights on my Harley. Have for years in Md, and now in SC.
All states must follow the 108 standard. I didn't say anything about selective enforcement.
Stop lamps, including the CHML, must be steady burning. However, as mentioned above, pulsing or modulating has been recently approved.
joelmic
joelmic
stl mo
Yes, just so there was no misunderstanding... my OP was all about lights that would only strobe for a second or so, then go solid.
Hawkman
South Carolina
bwager
syracuse
DODGE RAM (09-18) X3B LED BRAKE LIGHT​
Headlight Revolution
Jammer24
new york
2014,2020 Rebel
I triked my goldwing and did an led conversion. A there little units wired inline that allow me to choose one of many patterns... when I get home from work I will post a picture....worked very well.
mrarmy
Central Texas
I installed these on my 2020 Rebel and they work with no issues! Alla Lighting 2600lm T10/T15 912 921 LED Strobe Bulbs, Red Flashing Center High-Mounted Stop Lights Lamps(3rd Brake Lights), Super Bright 922 W16W 906 4014-SMD Replacement for Cars, Trucks, RVs, SUVs. They strobe 3 times then light solid.
Jammer24
new york
2014,2020 Rebel
1000009828.jpgthis is what I wired inline for my trike brake lights. Worked well....if I can locate a link for it I will post
moates49
