Jeep says "park outside" to 1 million Wrangler and Gladiator owners
Yardbird
Western NC
Jeep says "park outside" to 1 million Wrangler and Gladiator owners​
Story by Justin Banner
3 min read
When most people picture a Jeep, they think of a bulletproof off-roading SUV conquering places like Johnson Valley, California, and Moab, Utah. But recalls seem to come for every vehicle eventually, and a new one affecting 2021–2025 JL Wranglers and JT Gladiators is big and notable: Owners of those vehicles are being advised to park their Jeep outside, as there is a chance they may catch fire even with the key out and the engine off.
Which Jeeps Are Affected?​
This recall and notice hits every version of the JT and JL sold with every engine and transmission combination. From the 2.2-liter turbodiesel found in international markets to the Wrangler 392 and its Hemi V-8 here in the U.S., all are part of this recall. It also affects Wranglers and Gladiators in both left- and right-hand-drive configurations. Altogether, 1,076,999 Jeep owners are being told to park outside. But since the Gladiator sells just a bit slower than the Wrangler, the JL is taking the brunt of the advisory, with 787,887 vehicles affected.
The good news is that any Jeep Gladiator or Wrangler with a production date after December 2, 2024, is deemed safe, as the defect was caught and corrected. Jeep Wranglers built before June 24, 2020, and Gladiators built before August 18, 2020, use a different part that did not have the defect.
It Catches Fire With the Engine Off?​
What makes this unusual is that the recall and fire risk are related to the electrohydraulic power steering pump. This system is powered down when the key is in the off position, which one might think would be enough to prevent a fire.
But the electrical connection between the wiring harness and the circuit board creates high resistance. That was due to the connector header of the circuit board being manufactured out of tolerance and being too loose. That looseness causes an increase in resistance that can generate enough heat to melt the connector and, because power steering fluid can catch fire when heated enough, lead to a catastrophic burning of your JT or JL.
Even if it’s turned off, there is still the potential for the plastic and metal to retain enough residual heat or for the plastic to be smoldering enough to cause the fluid to catch fire with the engine off and the key out of the ignition.
According to the report from NHTSA, Jeep was aware of 47 instances potentially related to the melting connector between July 2019 and March 2026. None resulted in a fatality, but Jeep is aware of one potential injury related to this defect.
Is There a Fix?​
The fix for now is simply to inspect for signs of an overheated connection or a melted connector and repair or replace those parts as necessary. However, according to Stellantis’ Customer Services Field Operations notice related to this recall, a permanent fix is still being developed.
From the sounds of it, the connector and possibly the pump will be replaced if there is evidence of melting. We theorize that the approved repair will involve an intermediate connector harness to match the tolerances of both the existing circuit board header and the existing harness connector. We reached out to Stellantis; we will update this story once if we receive a response.
Dealers should be aware of the recall now, but official notices to owners will start on July 9, 2026. VINs should be searchable on the Mopar and NHTSA recall sites by July 11.
https://www.msn.com/en-us/autos/aut...1&cvpid=6a2d94fbe24d4f419f6b3f73cf69c692&ei=7
MrBonez
Central Alabama
2008 Laramie Quad Cab
OK - How about they park it outside the dealership service department and see what happens?
I'd bet there would be at least one interesting event that takes place out of about a million possible chances of it happening.
jejb
NW Arkansas
That sucks and all. But when I think of Jeep, I do NOT think of "a bulletproof off-roading SUV". Consumer Reports ranks Jeep 24th out of 26 brands for reliability. And the Wrangler in particular is rated pretty low when it comes to that metric. I'm sure they are fun, but bulletproof they are not.
Daw14
South Florida
At least jeep is getting a recall , when our rams have had esp problems since they were introduced.
markabby
Monticello, Kentucky
2020 Limited
ha...my son's GF just bought one. Wrangler i believe.....he asked me about wiring up the panel box so she can charge it. I asked how many miles does she get on a single charge.....he replied 20 to 22 miles. LOL
seriously....22 miles?? I don't think it's worth the cost of electricity. It seemed so profound that i had to look it up...and, to my surprise, it's true.
Ram201963
