kicker 10" subs
Ellamay_the05v8
4.7 Magnum v8
So my truck battery died and it took a couple weeks to replace it. Prior to the battery dyen the subs hit hard and they werent blown, but now when i put my new battery in which is the same size and brand and all that my amp is all hooked up but the subs wont hit at all its like they aint even there. Do yall know whats up or any way to possibly fix my issue?
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
what head unit are you running? I have an aftermarket unit and I have to reset everything any time I disconnect the batteries.
Ellamay_the05v8
Ellamay_the05v8
4.7 Magnum v8
Idk what head unit it’s a used truck and it came with everything in it I’ve done some work on it but I’ll reset it this weekend thank you bubba
Ellamay_the05v8
Ellamay_the05v8
4.7 Magnum v8
It was the stupidest thing that could have happened basically you know those two little blocks that connect with a wire under the hood and connect the battery to the amp they just had disconnected itself so I just had to reconnect them with a better wire and now they hit harder than my uncles 15”s
gville35
